Whether you’re a fitness enthusiast, an athlete looking to cross-train, or someone recovering from an injury, incorporating water exercises into your routine can offer numerous benefits.
If you’re seeking an effective way to intensify your aquatic workout, aquatic ankle weights might be just what you need. These innovative fitness accessories are designed to add resistance and challenge to your lower body exercises in the water, helping you build strength, improve endurance, and increase overall fitness levels.
To find out more about this great fitness and health-improving invention, keep reading our article. You will learn what to look for when buying, which are the five best models, and how to use them most effectively.
How To Use Water Ankle Weights?
Using these weights is a straightforward process that can enhance your aquatic workouts. Here’s a step-by-step guide on how to use them effectively:
Start With The Right Equipment
Ensure you have a pair of waterproof ankle weights which are specifically designed for aquatic use. Look for adjustable straps and materials that are resistant to water.
Warm-Up
Begin your workout with a brief warm-up routine. This could include gentle stretching, light walking, or jogging in the water to prepare your muscles for exercise.
Secure The Ankle Weights
Put on the pool ankle weights by wrapping the adjustable straps around your ankles. Make sure they are snug and secure but not too tight to restrict circulation or cause discomfort.
Begin With Simple Exercises
If you’re new to using weights, start with basic exercises to get accustomed to the added resistance. Consider exercises like leg lifts, scissor kicks, or knee raises, which target the lower body muscles.
Maintain Proper Form
As you perform exercises with ankle weights, focus on maintaining good form and posture. Keep your core engaged, shoulders relaxed, and movements controlled. This will help prevent injuries and maximize the benefits of your workout.
Gradually Increase Intensity
As your strength and endurance improve, you can gradually increase the intensity of your workout. You can try more challenging exercises such as deep-water running, jumping jacks, or flutter kicks to further engage your muscles.
Stay Hydrated
Remember to stay hydrated throughout your workout to prevent headaches. Even though you’re in the water, it’s important to drink water regularly to prevent dehydration.
Cool Down And Stretch
Once you’ve completed your workout, take some time to cool down and stretch your muscles. This will help prevent muscle soreness and promote flexibility.
Clean And Dry Your Ankle Weights
After each use, rinse off the wet ankle weights with fresh water to remove any chlorine or salt residue. Allow them to dry completely before storing them in a cool and dry place.
Are Water Ankle Weights Effective?
Yes, water ankle weights can be highly effective for enhancing your aquatic workouts and achieving various fitness goals.
These weights add resistance to your lower body exercises in the water, making your muscles work harder. This increased resistance helps to build strength and tone the targeted muscles, including the quadriceps, hamstrings, calves, and glutes.
Engaging in water exercises with ankle weights can elevate your heart rate and increase the intensity of your workout. This combination of resistance and cardiovascular training helps to improve your cardiovascular endurance. It enhances your lung capacity, boosts circulation, and promotes overall cardiovascular fitness.
Why Use The Ankle Weights In Water?
Water workouts, in general, are low-impact, meaning they put less stress on your joints compared to exercises performed on land. Pool ankle weights allow you to maintain the low-impact nature of your workout while still providing resistance and strengthening benefits.
What Exercises Can I Use The Weights For?
Their versatility allows you to customize your workout routine and target specific muscle groups or fitness objectives. The weights can be used for a wide range of aquatic exercises, such as:
- water aerobics
- jogging
- kicking drills
- leg lifts
- and more.
NOTE: I earn a commission when you buy a product from the links in the reviews.
Best 5 Water Ankle Weights – Reviews
Sportneer Water Ankle Weights
The Sportneer ankle weights for swimming stand out among other water ankle weights on the market due to their utilization of high-density EVA foam material. This premium material ensures durability, safety, environmental friendliness, waterproofness, odorlessness, chlorine resistance, and quick-drying properties.
With the quick release and detachable Velcro feature, they can be effortlessly worn or removed. They are thoughtfully engineered with an ergonomic structure, incorporating a recessed design to snugly fit around your wrists, ankles, or arms. Designed to provide both flotation and weight resistance in water, the aquatic ankle cuffs offer a range of applications. They are ideal for swimming classes, water-based physical therapy, muscle development, and aquatic training.
- Main Features:
- ergonomic design – usable on wrist, arm or ankle
- EVA foam material – durable, safe, environmentally friendly, waterproof, odorless, chlorine resistant and quick-drying
- quick release Velcro for easy and fast adjusting
- multi-functional – both flotation and weight resistance
GYMENIST Water Proof Ankle Weights
This set includes a pair of ankle weights, with each weight weighing 2 LB. The adjustable strap ensures a secure fit and allows you to customize the size to achieve maximum comfort during use.
These ankle weights are waterproof, making them perfect for a wide range of water activities. They are designed to withstand the demands of water environments without compromising their functionality. The ankle weights feature an adjustable hook and loop strap, allowing you to easily adjust the size to find the perfect fit. This ensures optimal comfort and prevents the weights from shifting during exercise.
- Main Features:
- each ankle weight weighs 2LB
- easily adjustable hook and loop strap
- ergonomic design for optimal comfort
- one size fits all design – strong and durable grip makes sure they stay on
Kiefer Ankle Weights For Water Aerobics
These ankle weights feature a soft and durable neoprene casing that ensures a comfortable fit during your workout sessions. The Velcro buckle adds extra security, keeping the weights in place while you exercise. They can be conveniently clipped together, allowing you to use them as a weight belt for water polo drills. This innovative feature helps develop leg and core strength, making it an ideal training tool for water polo enthusiasts.
Designed with your comfort in mind, they are made with materials that prioritize comfort during use, and their user-friendly design ensures easy and hassle-free attachment and removal.
- Main Features:
- 1 pound for each ankle weight
- durable and soft neoprene casing
- can be attached together to be used as a weighted belt
- Velcro buckle for strong grip and security
APEXUP Adjustable Water Proof Ankle Weights
APEXUP presents adjustable water ankle strength training weights crafted with the utmost quality. These weights are filled with iron sand, ensuring a compact profile while providing effective resistance. The sleeve material is soft and breathable, guaranteeing maximum comfort during your workouts.
The package includes two ankle weights, each consisting of 5 weight modules weighing approximately 0.67 lbs each. This modular design allows you to adjust the weight of each ankle weight from 1 to 3.5 lbs. Start with lighter weights and gradually increase as you progress, tracking your improvement along the way.
The adjustable Velcro straps ensure a secure fit, making them suitable for all sizes.
- Main Features:
- modular design – 5 weight modules weighing approximately 0.67 lbs each
- filled with iron sand – compact profile with effective resistance
- can be used as arm weights
- soft and breathable material
- Velcro strap for optimum grip and comfort
TRC Recreation Super Soft Foam Aquatic Ankle Weights
Elevate your aquatic fitness routine with this pair of fitness ankle weights for swimming, bringing an exciting challenge to your workouts.
Specifically designed for physical therapy and aquatic fitness, these ankle wraps are perfect for adding resistance during water exercises. They intensify your workouts, helping you build strength and improve endurance.
Crafted from lightweight closed-cell foam, these ankle wraps remain buoyant in water and do not absorb water. Their lightweight nature enhances your mobility and comfort during aquatic workouts.
These ankle wraps are not limited to ankle use only. You can also utilize them on your wrists while in the water, providing resistance and adding an effective arm workout component to your routine.
- Main Features:
- closed-cell foam material gives them strong underwater resistance
- 100% buoyant and water proof design
- lightweight for both comfort and mobility
- can be used for both ankles and wrists
- strong but comfortable grip provided by Velcro straps
Conclusion
In summary, water ankle weights are effective tools for intensifying your aquatic workouts, enhancing strength, and improving overall fitness. Incorporating them into your routine can lead to increased muscle engagement, cardiovascular endurance, and a greater range of exercise possibilities. With proper usage and care, water ankle weights can be a valuable asset in achieving your fitness goals in the water.
After your pool workout with the weights, you can relax your muscles in two ways, depending on your preferences. The first one is an ice bath. On the other hand, you can relax in a warm bath laying on a full-body pillow. Or you can stay in the pool and try diving with underwater scooters.
I’m a psychologist and life coach sharing my inspects and knowledge about relationships, mental and physical health, and tips on how to make your everyday life comfortable for living.
