You’re surely not the only person who’s dealing with swelling, inflammation, or even lipedema.
And you’re not the only one who gives your hopes up when finding out there’s a vibration plate for lymphatic drainage.
The lymphatic system plays an important role in helping to move fluid throughout the body, as well as removing waste and toxins. Lymphatic drainage is a type of massage that can help to stimulate the functioning of the lymphatic system. It is an effective way to reduce swelling and inflammation, flush out toxins, improve circulation and boost immunity.
The vibration plate has a similar effect. Using this machine, you can make your home into your everyday massage salon. In this article, we will see how the machine works, what are the benefits, and which models to buy to get the best lymphatic drainage effect.
Lymphatic Drainage – Massage And Vibration Plate
How Does Lymphatic Drainage Work?
Lymphatic drainage massage uses light pressure to gently stretch and manipulate the skin in order to move lymph fluid away from congested areas. This helps promote healing by encouraging the flow of new nutrient-rich fluids throughout the body. The benefits of this type of massage are numerous and it can be used both preventatively as well as therapeutically.
Does A Vibration Plate Help With Lymphatic Drainage?
Yes, vibration plate technology can help with lymphatic drainage. This type of therapy accelerates the movement of fluids through the body by using specific frequencies and vibrations which stimulate the muscles and lymphatic system.
This helps to speed up the natural process of detoxification and encourages more efficient delivery of nutrients throughout the body. Vibration plates can also help to reduce inflammation, improve circulation, and enhance range of motion, all of which promote better lymphatic drainage.
How To Use a Vibration Plate For Lymphatic Drainage?
To perform lymphatic drainage using a vibration plate, start by standing on the vibrating platform for about 10 minutes at the lowest setting possible. Increase the intensity gradually as needed until you reach a comfortable level that you can sustain without discomfort. Finish with 10 minutes at a lower setting and then end your session with gentle stretching or walking around.
Your final step will surely be taking a relaxing bath. You deserved it!
How Often Should You Use The Machine?
There’s no rule on when to use it or how often but follow your feeling. You can do a session in the morning and one in the evening. Once you have the machine in your home, you can use it anytime you feel that you need treatment.
Adding regular vibration plate sessions into your self-care routine can help support your lymphatic system for improved long-term health.
NOTE: I earn a commission when you buy a product from the links in the reviews.
Best 3 Vibration Plate For Lymphatic Drainage Reviews
VT Vibration VT027 Vibration Plate Machine
The VT027 is a vibration plate machine with a unique twin-coupler design that allows for high-performance vibrations in an ultra-thin body (4.5” height). With its large platform (24.8”) and 10mm amplitude, this machine can challenge even the most experienced users.
Even at its highest vibration intensity, the VT027 runs incredibly quiet – perfect for those who want to use it in a shared space. Its vibration frequency can be conveniently adjusted from 5Hz to 14Hz in 20-speed levels.
- SPECIFICATIONS:
- remote control
- automatic operation mode
- it’s a corded electric machine
- 4 mounting positions ensure stability
LifePro 3D Vibration Plate
With its dual motor and 3 vibration modes, the machine can provide you with a great lymphatic drainage experience. Not to mention, it’s also very easy to store away when you’re done using it.
Maximal weight the machine can hold is 330 lbs. You can run it using the remote control, just like most vibration plates. It’s for your health and exercise. You can strengthen your muscles as well so it’s great for multiple people to use it. Everybody will have benefits from it.
- SPECIFICATIONS:
- 30.5 x 17.3 x 5.9 inches
- remote control included
- 4-15 Hz
- maximal weight is 330 lbs
Natini Vibration Plate
It comes with a Bluetooth speaker and an external USB port so you can play your favorite tunes while you work out. The LED lights bar on the body vibration machine will also flash in sync with the volume level of the music to keep you motivated during your activity.
With automatic walking, jogging, and running modes designed for different exercise demands, there’s something for everyone with the Natini. Plus, it has two rollers on the bottom for easy transportation and four antislip suckers for stability while using.
- SPECIFICATIONS:
- Bluetooth speaker with LED lights
- maximal load is 310 lbs
- rubber massage mat is included
- it comes with remote control
Conclusion
All the models come with a remote control. All of them are adjustable so you can regulate as much vibration as you need/want. They are all pretty similar to use so there’s no special recommendation on which one to take. The only recommendation is to take the vibration plate for lymphatic drainage since it can really benefit your health condition. Combined with the lunar diet, you can get rid of accumulated water in your body.
I’m a psychologist and life coach sharing my inspects and knowledge about relationships, mental and physical health, and tips on how to make your everyday life comfortable for living.
